Activity Forums Apple Final Cut Pro Legacy Drop Frames vs Non Drop Frames
  • Drop Frames vs Non Drop Frames
    Posted by Jim Reed on August 25, 2010 at 4:17 pm
    Whenever I export a mov to work with in Annotation Edit, I send it out as non drop frames. Is this the best way to export to A/E? A/E will take it either way and I can send it out from A/E to DVD SP either way.
    Jim Reed replied 16 years, 1 month ago 2 Members · 2 Replies
  • John Fishback
    August 25, 2010 at 6:07 pm
    The advantage of Drop Frame code is it can be read as actual accurate time. For instance, 30 minutes of NDF is longer than 30 minutes. 30 minutes of DF code is exactly 30 minutes. See this explanation by Larry Jordan.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Jim Reed
    August 25, 2010 at 6:35 pm
    Thanks. That’s just what I needed.
