Activity Forums Apple Final Cut Pro Legacy drop frames on xserve?
  • drop frames on xserve?
    Posted by Ming Saadprai on January 22, 2006 at 11:36 am
    As you can see from my profile, I seem to be running a somewhat souped-up system. Why do I still get drop frames upon playback? My project is 27.5MB and am working with about 60hrs of footage at DV-PAL compression with a maximum of 3 video track and 9 audio tracks. Some of my timelines extend to about 1hr and I usually have 3X1hr sequences open at a time. Then again, shouldn’t the system be able to handle it? Running the Blackmagic Disk Speed Tool, I noticed that my disk read/write speed tends to fluctuate on the X’serve, decreasing throughout the day. Any ideas?
    4 X 2.5Ghz PowerPC G5
    2 GB DDR2 SDRAM
    FCP Studio
    Xserve RAID 2TB RAID 5
    Kevin Monahan replied 20 years, 7 months ago 4 Members · 4 Replies
  • Ming Saadprai
    January 22, 2006 at 11:40 am
    Sorry guys, an updated profile.
    2 GB DDR2 SDRAM
    FCP Studio
    Blackmagic Extreme
    DELL 2405FPW
  • Chris Poisson
    January 22, 2006 at 5:08 pm
    Ming,
    Try an audio mixdown.
    Have a wonderful day.
  • David Roth weiss
    January 22, 2006 at 6:05 pm
    Ming,
    If you upgraded to Quicktime 7.0.4 when it was first released this could easily be causing your problem. It did create this problem for me. If so, check the Apple site for the cure, which is a rollback to QT 7.0.1 and then an install of 7.0.3
    DRW
  • Kevin Monahan
    January 23, 2006 at 7:49 pm
    Might also be that Dell Monitor. I’ve seen a KB article on Apple about Dells causing dropped frames recently. No URL, sorry.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
