Activity › Forums › Apple Final Cut Pro Legacy › drop frames on 720p capture
  • drop frames on 720p capture
    Posted by Alejo Yael on November 15, 2007 at 9:08 pm
    hola forum
    ok i got the material of a project to digitalize , i is a historic battle of San Martin a proser in argentina, a lot of horses, dust etc, so the thing is, the tapes have A LOT of drops everywhere (the camera were rent… apparently not in good conditions) . when we try to capture, final cut will abort or make a new clip depending on the preference setting, but we lost almost 10 seconds of footage at the beginning and the end of every shot…not good.
    because of my english let my clarify. 2 problems; the inaccurate of jvc hdv capture (making a lot litttle files and not only in star/stop ) and all the drops in witch final cut will make a new clip. but not in a good manner
    i want to hav it like is on the tape with the drops and everything but complete.
    so i duplicate the master with a new timecode, but it did
    Alejo Yael replied 18 years, 10 months ago 4 Members · 11 Replies
  • 11 Replies
  • Jeremy Garchow
    November 15, 2007 at 9:10 pm
    Modify the capture preset so that you cut down on the amount of preroll.
    Jeremy
  • Gordon Gurley
    November 15, 2007 at 10:02 pm
    If you are really desperate, set to Non controllable device and do a capture now. I will do it’s best to get everything. Of course, you will have no TC to reference later if need be.
  • Matthew Nelson
    November 15, 2007 at 10:12 pm
    I had an issue were the operator was trigger happy with a camera on free run. What I did was capture the tape as a non controllable device. Then I laid that clip back to a new tape with continuous TC. Then I logged and batched from the new tape. The reason for the extra steps and time is that I now have batched media I can recapture and relink to if FCP took a dump.
  • Jeremy Garchow
    November 15, 2007 at 10:19 pm
    [mjnmedia] “I had an issue were the operator was trigger happy with a camera on free run.”
    An editor’s dream. It really can’t get much better than that.
  • Alejo Yael
    November 16, 2007 at 12:57 am
    thanks everyone…
    jeremy…pre roll is set to 5 frames… thanks
    “if you are really desperate, set to Non controllable device and do a capture now. I will do it’s best to get everything. Of course, you will have no TC to reference later if need be. ”
    yes i am…i
  • Jeremy Garchow
    November 16, 2007 at 1:09 am
    [alejo yael] “jeremy…pre roll is set to 5 frames… thanks “
    Right, if you set preroll to less time, you won’t lose as much footage on the tc breaks. As of now, you will lose at least 6 seconds at each tc break. If you change preroll to one second, you will gain 5 seconds back.
    Make sense?
    Jeremy
  • Alejo Yael
    November 16, 2007 at 1:17 am
    right, by default will be 6 sec, and of corse it make sense….i have that set to 5 frames…
    alejo
  • Jeremy Garchow
    November 16, 2007 at 1:26 am
    [alejo yael] “5 frames… “
    Oops I misread. Thought you said 5 seconds, not frames.
    FCP 6.0.2 has added better HDV support, are you in the middle of this project or just starting?
  • Alejo Yael
    November 16, 2007 at 1:39 am
    well… in the middle (i hope…if not will be endless) …and yes the suport of FCP is better and olso better with the update of the firmware of the BR-HD50…
    but i cant not make it work with capture now, non controlable device and HDV for codec…
    Walter Biscardi, Jr. was not shure abaut it…
    “it’s possible this doesn’t work in HDV to be honest. I’ve never tried that.
    We have been successful doing this with DV, DVCPro HD and uncompressed formats using FCP.”
    somebody knows?
    thanks for the help
    alejo yael
  • Jeremy Garchow
    November 16, 2007 at 4:34 am
