Drop Frames in Premiere with good PC. What is happening ?
Hi guys good morning !
I’m going to the forum because I don’t know what to do anymore.
I’ve been trying to solve the Drop Frame problem for over a year now when using 4K 30/60 videos within the première. My point is not to reduce playback quality or proxy because then I don’t see much point in building a good PC for editing, spending money on a good video card and then having to lower the quality or having to proxy, but let’s situation and file types:
Recording Devices: DJI Osmo Pocket, Panasonic LX100, Panasonic GX85
Fps: 30-60
Resolution: 4K (3840×2160)
Codec: MP4
Duration: 1 to 8 minutes
Playback Quality: Maximum
My monitor resolution: 4K with upscalling to 175%
Processors tested: Ryzen 1600, 1700, 2700, 2700x, 3600 and Intel i5 9600k
Motherboard: Several tested
Video Card: GTX 1070 Ti
Memory: 64gb DDR4 between 2400 Mhz to 3000 Mhz
Discs: 2 SSD M.2 NVME x4
Premiere: All versions of Pro (current 13.1.3 – Build 44)Procedure:
I upload the video to the timeline
I apply a layer of Lumetri
I apply a transition effect like Cross ZoomREADY … Just enough for the video to start crashing when playing back playback …
Already tried to change driver, reinstall windows, install codec package but nothing ….
It’s been over a year since I changed configuration several times going through AMD and then returning to Intel which they say is better in the case of Premiere and nothing ….
Does anyone have any idea what it might be or some test I can do to try and solve this? It is not possible that anyone working with 4K files inside the premiere cannot fluently edit with a PC as described.
If anyone can help, I appreciate it.
