Activity Forums Apple Final Cut Pro Legacy Drop frames in FC using 8 drives VTrack
  • Drop frames in FC using 8 drives VTrack
    Posted by Dj Bouzourene on January 8, 2009 at 1:23 am
    I setup a new Apple 8 drives Vtrack directly attached to a MacPro, Apple 4GB card using FC studio2 and I keep getting drop frames, I tried all type of settings Raid 5, Raid 0, and Xsan script no luck:(
    Called VTrack today and they are now saying that I need to have all 16 drives to stop drop frames and that 8 drives is not enough, so basically I have to spend an extra $3,000.00 to get 8 more drives to get it to work.
    Can anyone please confirm that’s the only solution before I spend the money.
    Thx.
    Jeremy Garchow replied 17 years, 8 months ago 2 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    January 8, 2009 at 4:45 am
    What resloution are you working in and how fast are the drives running?
  • Dj Bouzourene
    January 8, 2009 at 2:13 pm
    The drives are running about 200MB/S using Decklink disk speed test.
    I’m using SD 10bit
    Thx.
  • Jeremy Garchow
    January 8, 2009 at 3:49 pm
    That should definitely get you through 10bit SD and then some. Your raid manufacturer is giving you the ole upsell speech, don’t listen to it for now.
    Do you have a capture card?
    Jeremy
  • Dj Bouzourene
    January 8, 2009 at 4:46 pm
    Blackmagic extreme, I tried everything no luck:(
  • Jeremy Garchow
    January 8, 2009 at 4:52 pm
    OK. so you have a 4GB fibre card, and a decklink card. What slots are those in?
    How much RAM do you have?
    Jeremy
  • Dj Bouzourene
    January 8, 2009 at 5:16 pm
    The Fiber card is in slot 2 (fastest) and the Blackmagic in 4
    4GB memory.
    I started this post to find someone with a VTrack storage that can confirm what the tech support are saying.
  • Jeremy Garchow
    January 8, 2009 at 6:11 pm
    You have a new MacPro or a pre2008?
    I’d put the fibre in slot 4 and the decklink in slot 2.
    Jeremy
