Activity Forums Adobe Premiere Pro Drop Frames and Stuttering Video on playback Pro Res 422HQ
  • Drop Frames and Stuttering Video on playback Pro Res 422HQ
    Posted by Armando Ciurana on November 19, 2011 at 3:17 am
    Hello!
    I’m editing a Pilot in Premiere Pro CS 5.5, this is my first real project in premiere pro, I trying to make the switch from FCS 3
    All the files are Pro Res 422HQ Captured with two Ki Pros, two cameras, 1TB of video files.
    Several Times the video playback on my sequence window drops frames or momentarily goes out of sync, just for 3 or 4 frames and goes back again in sync but with dropped frames in playback, I tried to edit in three different machines, two 8 core Mac Pros and one Mac Book Pro Core Duo, is the same.
    this is not critical but annoying, is this a usual thing in Premiere Pro CS 5.5? Should I transcode my files in order to get real time playback, like Final Cut Pro 7?
    Thanks in advance!
    Best!
    President
    Ciurana Dussauge Films Mexico
    Jim Wiseman replied 14 years, 9 months ago 4 Members · 6 Replies
  • Shane Ross
    November 19, 2011 at 3:22 am
    What graphics card do you have in the machines? Ones that can activate CUDA processing and make the Mercury Engine hardware based? that always helps…a LOT.
    Shane
    Little Frog Post
  • Armando Ciurana
    November 19, 2011 at 4:30 am
    Thank You Shane!
    I updated all the drivers and cuda drivers for the three machines, the graphic cards are>
    Mac Pro 8 Core: Ati Radeon 5770 and Nvidia Quadro 4000
    Mac Pro Cuad Core: Nvidia Quadro FX 5600
    Mac Book Pro: Nvidia GeForce 9600M GT
    After the update, both Mac Pros went slightly better but not great, still dropped frames and audio out of sync; the Macbook Pro, actually went worst.
    Please, I want to make this one in Premiere Pro, I´m trying to like the switch, do you have another solution?
    Is there a native codec for Premiere Pro?
    Thanks again!
    President
  • Tom Daigon
    November 19, 2011 at 4:36 am
    Armando. See if this helps.
    https://www.biscardicreative.com/blog/2011/11/fix-to-dnxhd-quicktime-stuttering-in-premiere-pro-cs-5-5-2/
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Shane Ross
    November 19, 2011 at 4:42 am
    [Armando Ciurana] “s there a native codec for Premiere Pro?”
    Nope…that’s one of the things missing that the others have. FCP has ProRes, Avid has DNxHD, PPro has…nada. It edited other formats natively. Some better than others. And because some formats are a bear, an Octo core mac with CUDA is the best way to edit with PPro. Quad cores…laptops…not the best.
    in my limited experience.
    Shane
    Little Frog Post
  • Armando Ciurana
    November 19, 2011 at 4:51 am
    I guess I have to stick with the 8 core then or get this one done in final cut if I want to go home and edit in pajamas and slippers hehehe
    Thank you again Shane!
    Armando
    President
  • Jim Wiseman
    November 21, 2011 at 8:18 am
    Playback works well with my MacPro 2010 5,1 3.33 GhZ Hexacore with 24Gb Ram and NVidia GTX 285. Source, Program Windows and External HDMI monitor on AJA LHi.
    Jim Wiseman
    Sony PMW-EX1,Pana AJ-D810 DVCPro, DVX-100, Nikon D7000, Final Cut Studio 2 and 3, Media 100 Suite 2.1, Premiere Pro 5.0 and 5.5, AJA ioHD, AJA Kona LHi, Avid MC, Hexacore MacPro 3.33 Ghz 24Gb RAM 120GB SSD, Macbook Pro 17″ 2011 2.2 Ghz Quadcore i7 8Gb SSD, G5 Quadcore PCIe
