Activity › Forums › Apple Final Cut Pro Legacy › drop frame video and timecode display
  • drop frame video and timecode display
    Posted by Alexandre Brandt on March 18, 2012 at 12:51 am
    Hello all,
    I have logged and transferred AVCHD footage to Apple ProRes 422(HQ). The format shows me 23.98 for the time code. My sequence is at 23.98. I noticed that my timecodes shows with hh:mm:ss:frame with a colon for “non drop frame” format and not a semicolon for drop frame formats which is the case for this 23.98 am I right ? Is there something I’m doing wrong ?
    Thanks for your attention.
    motion pictures + storytelling = ?
    -> FILMMAKING !
    Eric Keto replied 11 years, 6 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    March 18, 2012 at 4:42 pm
    AFAIK, the behavior you’re seeing is normal… just as long as the frame rate is reported right, which, in your case it seems to be, you don’t have a problem.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • John Christie
    March 18, 2012 at 5:40 pm
    People often confuse frame rate with drop frame, assuming that 23.98 is drop frame and 24 is non drop frame. FCP doesn’t provide 23.98 drop frame as a time code option. This isn’t an issue unless you’re formatting your shows for broadcast.
    I once heard someone at a user group meeting say that he never shot drop frame because the pictures looked “stuttery” from all the dropped frames 🙂
  • Alexandre Brandt
    March 18, 2012 at 8:43 pm
    ok
    -> FILMMAKING !
  • Eric Keto
    April 1, 2015 at 6:21 pm
    Hey John, I’m having the very problem you’re referencing here, any idea what I should do if I am formatting my edit for broadcast? https://forums.creativecow.net/thread/344/36575#36599
