Drop Frame Timing
I am finishing a project to HDCam for broadcast. The project is 6 22 minute episodes, shot in XDCAM EX, at 23.976 (35 mbits/sec). My delivery requirement is HDCam 59.94i Drop Frame. All episodes were cut at 23.98, and timed to fit the 00:22:20:00 timing required by the broadcaster. I have output the 23.98 sequences at their current settings, and then imported those files back into FCP. When I drop those files into a 60i sequence, FCP adds the pulldown which looks fine, and if the sequence is set to Non Drop Frame, the timing is exactly the same. My problem is, when I set the sequence to Drop Frame timecode, it ends up being exactly 14 frames over time.
I know that Drop Frame is just another way of counting, and that it does not add or take away frames, but is this normal? Should I be re-timing the 23.98 edits to compensate for this?Thanks!
