Drop frame problem when capturing.
Hello all,
I’ve been filming HDV 1080i on DV cassettes on a Sony HVz5.
My first problem is that when capturing some shots whiteout timecode break FCP has been making 2 clips with a 4 or 5 second break in timecode between them. If I re watch de tape on the camera and recapture the same point (between the two clips) their is no problem, no drop frames, no 3 second of missing information.
The second problem, in the same “style” is that I have other shots with a 1 drop frame in them in deed. FCP stops the capture and sais: “Stream Problem – Capture was stopped due to a problem with the incoming stream. This might be a problem with the tape. All media up to this point has ben preserved.” I understand that their is a drop frame but I’d to capture over that (as I have been doing for years in DV format).I wanted to know if the first problem comes from the fact that I am capturing HDV on a Western Digital Mac Book studio 1To (its a 7200 rotational rate) hard drive, the camera is connected in FireWire 800 to the drive, and the drive to my MacBook pro by FW800. I capture all the footage on the hard drive. I’ve been working that way with normal DV (which has the same data rate) since years and I had no problems.
A last peace of info that might be useful is that when I wanted to log clips say from 00:00:03:15 to 00:57:04:12 (almost one hour), FCP did not find beginning time code and said Error. (the starting timecode does however exist). I connect the camera in iLink.Can someone tell me whats going on ? Should I try capturing the footage with a real transfer machine and not the camera ? Is their a setting in FCP that I’m not aware of ? I’d like to try to keep it simple because I have 18 tapes now and have some more to shoot the next 3 days.
Thank your for your kind attention and your potential help.
motion pictures + storytelling = ?
-> FILMMAKING !
