Activity › Forums › Apple Final Cut Pro Legacy › drop frame issues
drop frame issues
Posted by Edgar Ojeda on October 18, 2005 at 1:07 pmhey guys i am new to the cow (great site) and have an issue with drop frames. it seems lately when i capture footage my final cut drops frame–also when i playback on the timeline it also drops frames–even when it comes up to a simple dissolve—-drops frames—-i have a g5 dual 2.0 with lacie 250gig external hard drive thanx in advance…
Phil Brown replied 20 years, 11 months ago 7 Members · 14 Replies -
Bouncing Account needs new email address
October 18, 2005 at 1:57 pmDo you RENDER the dissolves, at the full quality setting?
Edgar Ojeda
October 18, 2005 at 3:18 pmyes i make sure i render everything—this has been a recent problem i would say the past few weeks. i mean i would have to eject my hard drive (lacie external) turn it off then back on again (about 3 or 4 times) then i would take a chance of dropping frames or not its like taking a gamble. maybe a system problem? thanks for reply.
October 18, 2005 at 4:02 pmYou are using an external FW drive for capture and render scratch?
That’s not really recommended by Apple (although many do use them).How FULL is the drive?
Espnetboy3
October 18, 2005 at 4:42 pmI heard your not supposed to use your regular internal drive to capture and render, so wouldnt you use your drives just for media?
Edgar Ojeda
October 18, 2005 at 5:05 pmyes i use the external firewire drive for media capture and render scratch—i mean it worked like a charm (bout 8 months) its just recently i have encountered drop frames–happens more often lately—the hard drive is 250g—i have 140g available.
Edgar Ojeda
October 18, 2005 at 5:06 pmi use a lacie external firewire drive 250g for media and render
October 18, 2005 at 6:24 pmYou are “SUPPOSED” to install additional INTERNAL drive(s) so that you don’t use your system drive for Capture and Render.
Yes, (as I said) many FCP editors DO use external FW drives, but they can be problematic (as many also find) due to FW bottleneck (speed) issues.
Another “approved” storage method is to use externaldrives, formatted as a RAID(s) connected via SCSI .
Julie Bigford
October 18, 2005 at 6:30 pmMatte: You are “SUPPOSED” to install additional INTERNAL drive(s) so that you don’t use your system drive for Capture and Render.
Can you achieve this by partitioning your internal drive?
