Activity › Forums › Adobe Premiere Pro › Drop Frame Display in CS6 sequence?
  • Drop Frame Display in CS6 sequence?
    Posted by David Intrator on June 26, 2012 at 12:49 pm
    Re: Premiere Pro CS6
    Is there a way to display timecode in a sequence as drop frame? I have P2 footage at 23.976 fps. The sequence indicates “24 fps Timecode” as the display. I assume that is non drop frame. The only other relevant display option is 30 fps non drop frame. Can’t seem to find a way in sequence settings to convert display to drop frame.
    What am I missing here?
    Thanks.
    david
    Brian Cooney replied 13 years, 8 months ago 2 Members · 1 Reply
  • Brian Cooney
    January 10, 2013 at 2:38 pm
    if you pull footage into a fresh sequence it will ask you if you want to convert the sequence to the footage, in which case it will convert the sequence to ndf or df to match the footage
    MotionFoundry, Inc. Video Post
    Clients: GM, AOL, Kohl’s, 3 Doors Down, IKEA, Kelloggs, Toyota, Thomas Nelson, NASCAR Affiliates
