Activity Forums Adobe Encore DVD drop area
  • drop area
    Posted by Federico Pangeri on June 16, 2009 at 8:10 am
    Sorry about the stupid question, i have some problems to create the drop area of a button on encore cs3.
    I’ve the menu ( animated menu created from after effects)
    i’ve imported the psd file than assigned motion audio and video (after effects comp) to that menu. now i’m tring to assign the a button.
    No problem for the Highlight button, but i need a bigger drop zone for that btn.
    i’ve tried to rename the Highlight with (=1) and the drop (or selection area as u want to call it) with (=2) but nothing happen.. than i’ve tried to rename the highlight with (=2) and the selection area with (=1) but nothing happen jet..
    could someone help me pls?
    sorry for my poor english..
    tnx u in advance
    hsab
    Jon Geddes replied 17 years, 2 months ago 4 Members · 5 Replies
  • Joe Bowden
    June 16, 2009 at 1:30 pm
    Sorry, but I’m not sure I understand. What are you trying to make bigger? The bounds of the button?
    Can you please restate the question?
  • Jeff Bellune
    June 16, 2009 at 1:54 pm
    Add a shape or text to the button group, and reduce the fill or opacity to 1%. That should force the object to take up space but still remain invisible.
    If you reduce the opacity or fill of the new object to 0%, then Encore won’t recognize the object and the size of the hit area won’t increase.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Joe Bowden
    June 16, 2009 at 4:12 pm
    Is that what was meant? Guess I needed more coffee…thanks, Jeff. 🙂
  • Jeff Bellune
    June 16, 2009 at 4:27 pm
    [Joe Bowden] “Is that what was meant? Guess I needed more coffee”
    Heck, I don’t know. I answered just in case that’s what was meant. 🙂
    -Jeff
  • Jon Geddes
    June 16, 2009 at 4:50 pm
    Well he did say nothing happened when he prefixed the layer with (=1) or (=2). Federico’s method for trying to increase the selection area will work providing that he also turns the opacity of the (=2) highlight to zero in the ‘Edit Menu Color Set’ options.
    Maybe nothing happened because he didn’t prefix the Layer Group with a (+). Not doing this would cause “nothing” to happen when he tries to create the button highlights in photoshop.
    Jon Geddes
    Motion Graphics Designer
    http://www.precomposed.com
