Activity › Forums › Maxon Cinema 4D › Driving Tag Align to Spline position parameter with audio
  • Driving Tag Align to Spline position parameter with audio
    Posted by Sebastien Mercier on December 12, 2018 at 7:23 pm
    Hi
    In align to spline TAG there is a position parameter wich make object moving along the spline.
    This parameter is % units
    Is there a way to drive it with audio like audio mograph effector do. That allow to move scale or rotate an objet depend the audio frequency or amplitude.
    I tryed with Xpresso but i can t find a node that output this frenquency or amplitude value.
    Any help ? please.
    Sebastien Mercier replied 7 years, 9 months ago 2 Members · 2 Replies
  • Brian Jones
    December 14, 2018 at 4:43 pm
    percent in nodes (xpresso) always runs from 0 – 1 so in between whatever node you are driving with and the align tag percent you need a range mapper node – this is one possible way
    12952_sounddrivesalign.zip.zip
  • Sebastien Mercier
    December 22, 2018 at 9:53 am
    thank you very much it work.
