Activity Forums Blackmagic Design Drivers 5.9.2 PAL DV field issues
  • Drivers 5.9.2 PAL DV field issues
    Posted by Uku Toomet on February 15, 2007 at 5:41 pm
    The captured video play back with reversed fields. Only way to compensate is to reverse fields in Premiere.
    Also, creating custom project with DV upper fields first doesn’t help.
    Can’t say/recall if it was an issue with previous codecs as well.
    Mjpg and Uncompressed works fine.
    Please support.
    Uku
    Kristian Lam replied 19 years, 6 months ago 4 Members · 3 Replies
  • Peter Corbett
    February 15, 2007 at 10:32 pm
    I’m getting this too. I hadn’t thought of the drivers.
    Peter
    Peter Corbett
    Powerhouse Productions
    http://www.php.com.au
  • Oliver Petz
    February 16, 2007 at 2:55 pm
    Same here !
    Unforunetely my whole DV-Pal-Footage ( captured with an older decklink-driver ) is playback with wrong field-order( Decklink-DV-Pal and Decklink-Motion-JPG-Projects )
    No way to mix up Motion-jpg and DV-Files on a Motion-Jpg Timeline . You have to change the field-order of the dv-Files in Premiere-Pro 2.0.
    Native captured DV-Files ( Premiere Standard-DV-Project,captured via firewire )cannot playback at all without wrong field order. If you change the field-order of these DV-Files in premiere ( Decklink-DV-Pal and Decklink-Motion-JPG-Projects )there is still the wrong field-order. Nothing has changed. this is realy strange….
    Sorry for my horrible english
    Greetings
    Oli
  • Kristian Lam
    February 21, 2007 at 6:00 am
    Please wait for the next driver update (v6.0) which will address this issue. I would expect the update to be available something soon.
    regards
    Kristian Lam
    Blackmagic Design
