Activity Forums Blackmagic Design Driver problem since 5.1.1
  • Driver problem since 5.1.1
    Posted by Felix Dames on January 11, 2006 at 3:17 pm
    Hi to all of you who are in trouble with Drivers later then 5.1.1
    – I noticed diffrent kind of problems with later drivers then 5.1.1
    some drivers demaged my PPro 1.5.1 so that PPro starts to crash down with or without error message so that I have to reinstall it and go back to 5.1.1 Drivers
    – some other later drivers had audio problems when PPro is conforming….clicks and crackles
    In short: the list of bugs is a way too long and too diffrent to write down them here! And it is not my job!
    ***NEW DRIVER NEW BUG***
    For me the solution is to use 5.1.1 drivers and the reason for this is they are ADOBE CERTIFIED!!!
    And most of you are working with adobe products! Like me!
    With these drivers I can work like my clients want to see me working 😉
    Make shure your video drivers for your graphic card are ADOBE CERTIFIED too!!! Otherwise it could be that After Effects crashes in RamPreview.
    Tip of the Day: I wait for the next ADOBE CERTIFIED driver later then 5.1.1
    ??? When is the next REAL DRIVER RELEASE ???
    My oppinion is that every driver later then 5.1.1 is a beta release
    So dear BMD Team:
    – what about a STOP of putting nice new things in the driver which are not so importend ?!
    – what about scripting a rock solid driver ?!
    – Why one driver for PCIe and PCIX which are totally diffrent Hardware? Why not two diffrent drivers for two diffrent hardware who are working at least?
    For me it seems that the BMD team ignores one importent point:
    THAT WE ALL HAVE PAID MONEY FOR THE HARDWARE AND IT IS THERE FUC*ING JOB TO RELEASE A FUNKTIONAL QUALIFIED DRIVER AND NOBODY OF US HAS TO REPORT BUGS OR WASTE TIME WITH IT! WE ALL CHOOSE THERE PRODUCT TO DO WHAT WE KNOW TO DO AND THAT IS CREATIVE WORK AND NOT BETA TESTING!!!
    Hope you get a solid system – mine is working good for me without serious errors!
    My System:
    DELL Precision Workstation 670
    Dual Intel Xeon 3,4 GHZ
    2 GB RAM
    SATA 10.000 u/s 74GB system drive
    SCSI 320 RAID 0 148GB (2x 10.000 u/s 74GB) drive for video and audio files
    NVidia Quatro 1400 PCIe Driver 77.56 (ADOBE CERTIFIED DRIVERS)
    BMD DecklinkPro DRIVER 5.1.1 (ADOBE CERTIFIED DRIVERS)
    Best Greetings
    Felix Dames
    Luke Maslen replied 20 years, 8 months ago 4 Members · 5 Replies
  • Luke Maslen
    January 12, 2006 at 6:16 am
    Hi Felix,
    Our engineers have been working over Christmas and the New Year and I think the next release you will see later this month will address the issues you have raised. Please also note that Dell Workstations are not certified for use with DeckLink cards and are currently unsupported by Blackmagic Design.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Felix Dames
    January 12, 2006 at 9:02 am
    Hi Luke,
    nice to know you are working on stable drivers! Thanks!
    I am a bit confused about the certification with DELL products like the precision workstation 670 which I own.
    https://www.adobeopenhd.com/certified_solutions/
    https://www.adobeopenhd.com/certified_solutions/dellohdcertsummary.pdf
    I am working with the dell 670 since April 2005! It works fine for me and my clients in SD mode in conjunction with a Sony digital BetaCAM Deck / Sony DV Recorder all over SDI connections with house clock sync generator. Firewire video connections like hdv work too.
    My opinion: why shouldn’t it work? The dell presision 670 have the right mainboard chipset Intel 7525 the disk drives (SCSI Raid0) are fast enough and the PCIX bus have two diffrent busses for real 100Mhz per PCIX Slot!
    Maby I am wrong and there are limitation or I forgot something importend?!
    But then question of the day:
    DELL is one of the biggest and largest computer manufactor and the cheapest one, so wouldn’t it be importend for Black Magic Design to support a company like DELL or at least the workstation 670?
    And when you are right and that workstation is unsupported why are so many video companies out there who sell the Black Magic Design cards in combination with DELL Workstation 670?
    I don’t know?!?
    I only started this post to tell people who have problems with BMD products that it could be importened to keep certifications in mind espacially for drivers.
    Regards,
    Felix Dames
    http://www.felixdames.de
    http://www.redsun-berlin.de
  • Bill Buchanan
    January 12, 2006 at 2:37 pm
    Felix:
    Very well said. When it comes to the alternative systems (non-AVID), I’m not sure which rule should apply: “You get what you pay for.” or “You don’t get what you pay for.”
    Bill Buchanan
    Buchanan Film Co.
  • Sameer Shrivastava
    January 14, 2006 at 12:05 pm
    Very rightly said about dell systems.
    I am also using a del sc1420 server since dec 2005
    Dual xeon 2.8, 800 fsb
    3 gb ram
    3 sata 1 disks raid giving 165mbps/145mbs
    6600 graphic card
    without any problem
    (except one driver realted problem of audio sync on master, which lot of other people have, having even more robust systems and even g5)
    other wise system works rock solid. initally i used the ati 16mb pci card which came with the system without any problms. But now i have installed a 16x pci express n vidia 6600 on the 8x slot. though i have to file the slot to make it accept it. The card work fine.
    I guess blackmagic does not certify dell systems because most of them does not have a 16x pci express slot used for graphic cards, except 670.
  • Luke Maslen
    January 16, 2006 at 5:09 am
    Hi Felix,
    OpenHD have certified PC’s from both HP and Dell whereas we have only certified DeckLink cards for use with HP PC’s. The reason for not certifying the Dells is that we received many customer reports regarding the Dell Precision Workstations 650 & 670. Some customers had no problems and found they worked brilliantly. Others could not start up their PC’s after installing a DeckLink card along with other PCI cards, especially some models of SATA cards and also non-NVIDIA graphics cards. Some of these PC’s shipped with NVIDIA cards (and worked fine) and others shipped with other cards and did not always work well. The exact driver version for the graphics cards also seemed to be very important.
    The problem for us was that even though there were just two models of these PC’s, the components inside seemed to vary and so we were unable to say that DeckLink cards would work with a particular model of Dell PC as one Dell Precision Workstation 670 could have different components to another Dell Precision Workstation 670.
    In short, some of these PC’s work very well but others did not. We had no easy way to determine whether a customer’s Dell Precision Workstation would work well with DeckLink cards and hence the decision not to support them even though they are great machines for many purposes.
    Regards,
    Luke Maslen
    Blackmagic Design
