Activity Forums Apple Final Cut Pro Legacy drive space & FCP
  • drive space & FCP
    Posted by Tony Birkholz on June 22, 2005 at 8:24 pm
    i need to make space on a external drive, want to delete all unused media from a FCP project and the media linked to those clips off the drive, whats the safest & easiest way to do so? -media manager?
    tony birkholz
    editor/cameraman (HD)
    winkincproductions.com
    Tony Birkholz replied 21 years, 3 months ago 2 Members · 2 Replies
  • Nick Meyers
    June 23, 2005 at 5:55 am
    if you logged and captured as smaller clips, you can
    Select the sequnce in hte browser,
    Apple F to open hte search window
    Search for: Unused Media in selected sequnce
    when it gert presented in hte search results window,
    select it all,
    SHIFT D (for delete) to open hte make offline wiindow,
    move to trash.
    check that your sequnce hasnt been afrected (it shouldnt be, but best to be sure)
    then empty the trash.
    if you did whole-roll captures, then Media Manager would be the best bet.
    DONT use “Use Existing” mode
    Use COPY mode, check the results, then manualy delete the original files using the Make Offline window
    Media Manger isnt perfect, and Use Exising is a one way street: if somewthing goes wrong, you’re toast.
    nick
  • Tony Birkholz
    June 23, 2005 at 4:20 pm
    tony birkholz
    tony@winkincproductions.com
