Activity Forums Avid Media Composer Drive self eject?
  • Drive self eject?
    Posted by Seb Ratcliffe on September 10, 2008 at 5:32 pm
    Have been working for a production company recutting some short form work.
    The system, adrenaline/ mc 2.7- hp tower, is in a bit of a mess as one of the drives had failed, so media recovered and moved, and so its getting pretty full.
    So a large bunch of omfs were transfered to a maxtor firewire drive.
    Projects reopened, relinked, recut to maxtor, working in 2:1. Via 400. Each spot is about 40″. Fine.
    When it comes to exporting, get halfway through doing qt ref and drive seems to eject itself?
    Causing avid/ pcu to crash. When try to open qt’s, same thing.
    The only reason I can think of is the drive isn’t fast enough. There is only firewire400 card on pcu.
    An 800 connection should be adequate for uncompressed though?
    Or maybe there is a bigger problem? Any help and ideas would be greatly appreciated.
    Many Thanks,
    Seb
    Seb Ratcliffe replied 18 years ago 2 Members · 2 Replies
  • Bouke Vahl
    September 11, 2008 at 11:54 am
    Dunno what’s happening, but (depending on the complexity of your show), exporting by ref does not always work. But 40″ should not be a problem.
    Few tips:
    Make sure all effects are rendered.
    Do NOT have ‘avid’ black in your timeline. If you need black, make a short video mixdown of black and insert that.
    Do not open QT’s that are half finished, you can’t trust them.
    If all fails, make a video mixdown and put it on top of the shows.
    Having a drive self-eject sounds scary, and i cannot imagine how that relates to QT export.
    Cheap drives are mostly sold formatted Fat32. I have seen that fail quite often. Format them as NTFS as soon as you can.
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
  • Seb Ratcliffe
    September 11, 2008 at 6:28 pm
    Had some black space in timeline, so will try the black mixdown thing, and/ or entire video mixdown.
    Couple of other things I forgot to mention.
    At some point there was ‘cannot export from this bin’
    and a quaratined omf thing. What is that?
    Figured at 400 drive couldn’t do the write/ read speed needed for 2:1?
    Will try to get drive reformated also.
    Thanks again
