Activity Forums Avid Media Composer Drive limit?
  • Drive limit?
    Posted by Justin Nirk on April 21, 2005 at 10:49 pm
    I have 6 LVD drives daisy chained and I want to buy 2 more drives to replace my two smallest drives. Is it going to be safe to install the new drives, daisy chain them, move the files from the smaller drives to the new ones, then disconnect the smaller ones? I’m running Avid 7.2 on a mac vs 8.1 Thx.
    R. Hewitt replied 21 years, 4 months ago 2 Members · 1 Reply
  • R. Hewitt
    April 22, 2005 at 9:52 am
    It depends on your SCSI drive controller. Many only support seven devices, which includes the controller itself. You’ll need to check which you are using. If you have the 15-device version you should be fine.
