Activity Forums Apple Final Cut Pro Legacy Drive Guru’s—eSATA stripping help??
  • Drive Guru’s—eSATA stripping help??
    Posted by Phillip Powell on July 17, 2007 at 5:20 pm
    Trying to help fellow editor set up his new eSATA stripped pair. In Disc utility he’s gotten
    as far as (from RAID Help) #3 Choose Striped RAID set Type from pop-up menu.
    But won’t let him drag discs wants to use into set list on right.
    Seems I had difficulty doing this last time as well, but can’t remember what I did to resolve it.
    Ideas?
    p2
    Phillip Powell replied 19 years, 2 months ago 2 Members · 4 Replies
  • Walter Biscardi
    July 17, 2007 at 5:34 pm
    Um, Stripping I can’t really help you with, might want to try the Cow Stripper’s forum with Ron Lindeboom. The section on tassels is quite good reading.
    Now for STRIPING some drives, well THAT I can help you with. Sounds like the RAID is already assembled, you need to Delete the RAID set first, then Create a New Raid, then drag in the individual drives.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Phillip Powell
    July 17, 2007 at 7:31 pm
    a stripping forum. Hmm…
    But back in the real world…been informed there’s a glitch in Disc Utility that won’t let you drag the drives (OSX 4.9 here) unless you re-start.
    So, gonna try that.
    p2
  • Walter Biscardi
    July 17, 2007 at 7:43 pm
    [pSquared] “a stripping forum. Hmm…”
    It would be entertaining, no? 🙂
    [pSquared] “But back in the real world…been informed there’s a glitch in Disc Utility that won’t let you drag the drives (OSX 4.9 here) unless you re-start.”
    That’s interesting. Haven’t seen that here but come to think of it we built 2 RAID’s in the past month but they were done with the ATTO software, not Apple’s.
    Let us know if it works.
  • Phillip Powell
    July 18, 2007 at 6:28 pm
    tech guy at OWC was right—quit and restart made possible to drag drives to create
    a RAID.
    Man, the time I’ve wasted…
    p2
