Activity › Forums › Apple Final Cut Pro Legacy › Drive degraded with Atto R380
  • Drive degraded with Atto R380
    Posted by Robert Torrance on October 25, 2007 at 10:47 pm
    I’m testing an atto R380 with proavio 8 drive array in raid 0 (will switch to 5 for job next week). Its been running for a month without a problem then suddenly I have one drive in degraded status. Now I don’t see the array on the desktop. Is the drive toast or is their a way to get it back (and maybe the data)? I know what failed is but don’t know about degraded in raid 0. Thanks in advance.
    Bob Torrance
    Robert Torrance replied 18 years, 11 months ago 4 Members · 5 Replies
  • Gary Adcock
    October 25, 2007 at 11:27 pm
    [Robert Torrance] ” Its been running for a month without a problem then suddenly I have one drive in degraded status. Now I don’t see the array on the desktop. Is the drive toast or is their a way to get it back (and maybe the data)? I know what failed is but don’t know about degraded in raid 0. “
    it’s RAID 0
    if a drive is in fault status the entire array goes down.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Robert Torrance
    October 25, 2007 at 11:31 pm
    I guess I meant is degraded the same as failure.
    bob
  • Walter Biscardi
    October 26, 2007 at 10:54 am
    [Robert Torrance] “I guess I meant is degraded the same as failure.
    Thanks”
    The ProAvio is the Maxx Digital Unit we’re running here as well and there’s really no reason to run that in anything other than RAID 5. As you have learned, RAID 0 loses the entire array if any drive in the unit fails.
    If you run RAID 0, you MUST run some sort of a backup drive like we used to do with our LaCie 2TB FW800 Backup drive.
    Walter Biscardi, Jr.
    Stop Staring Start Grading with Apple Color The new Color Training DVD now available!
    https://store.creativecow.net/p/66/stop_staring_and_start_grading_with_apple_color
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Soreyrith Um
    October 26, 2007 at 4:32 pm
    If the drive is only degraded, you might be able to save it by making an exact copy, and plugging the new drive into your RAID system. Of course, this assumes you can still read the degraded drive.
    If it was only a test and you didn’t lose any important data, then just call it a good lesson learned.
    http://www.HotSpotsOnline.com
  • Robert Torrance
    October 26, 2007 at 7:02 pm
    Lesson learned. Will try a copy just for fun. Then its raid 5. Thanks all
    Bob Torrance
