Activity › Forums › Apple Final Cut Pro Legacy › Drifting Sync
  • Posted by Paul Turlick on November 19, 2008 at 5:01 pm
    Hi all-
    In a nutshell here it is….cutting a short (5 minutes) piece (DVCPro HD). Footage digitized fine and is cutting fine…HOWEVER……several times yesterday the audio and video became out of sync. A restart of the system fixed it but it’s a bit disconcerting. Sound like a preferences thing perhaps?
    Any thoughts would be appreciated.
    -Paul
    Yoav Dagan replied 17 years, 10 months ago 4 Members · 3 Replies
  • Richard Sanchez
    November 19, 2008 at 5:12 pm
    In your user preferences, did you deselect the option to stop and warn you when you drop frames on playback? That could certainly account for it.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Bill Dewald
    November 19, 2008 at 6:31 pm
    Try the occasional mixdown render before you play back.
    Opt-apple-r
  • Yoav Dagan
    November 21, 2008 at 2:54 pm
    Hi Dominic,
    This issue is a known one (to me) since fcp 6. I usually works on 25fps but it might be in all the rates. some time when you import sound file to fcp it comes in the wrong frame rate. what i usually do is start fcp with only one new clean project, set it up with easy setup to the frame rate desired, bring the sound file in, put it on the time line and check that it is the right frame rate in the viewer, if its right, open the project that you work on, copy/paste. that’s usually works.
    Yoav
    Yoav Dagan
    Colourist / Onliner
    TiNT Post Production
    South Africa
