Activity › Forums › Adobe Premiere Pro › Drifting Out of Sync
  • Drifting Out of Sync
    Posted by Kevin Herrin on June 22, 2007 at 5:43 pm
    I have a rather large project where I am capturing old VHS(I know) tape to DVD. I am using a RCA to DV converter to capture into PP2. The problem the audio is getting out of sync. I have tried to capture in Non-Drop and Drop mode with no difference. The tapes are old shows that a ministry did, so I know that they aren’t recorded in LP mode. The project is DV 48hz, I did notice in the clip properties that interleaving is at 28.99 not sure if that would make a difference.
    Any ideas?
    Kevin Herrin
    Digital Dynamics Media
    Raleigh, NC
    Blast1 replied 19 years, 3 months ago 3 Members · 3 Replies
  • Steven L. gotz
    June 22, 2007 at 8:22 pm
    The problem may be the converter. What are you using?
    Steven
    https://www.stevengotz.com
  • Kevin Herrin
    June 22, 2007 at 9:46 pm
    I wondered if that might be it, though I don’t see the drift in the capture window. I have a TVOne DV 2001. It is a few years old.
    thanks
    Kevin
  • Blast1
    June 23, 2007 at 4:03 am
    [ddmedia] “The project is DV 48hz,”
    I assume thats your setting in Ppro, whats the setting on the converter, the TVone has three audio setting when it digitizes the audio 48khz, 44.1khz, 32khz, is the converter set to 48khz?
