Activity Forums Adobe Premiere Pro Dreamcolor and HDP2 question
  • Dreamcolor and HDP2 question
    Posted by Anhtu Vu on September 25, 2013 at 2:48 am
    Need some advice in setting up a Dreamcolor and AJA HDP2.
    I read a review by Jeremy Garchow where he suggested to set the Deep Color to ”on” and RGB Range to ”SMPTE” on the HDP2. The Dreamcolor is set on Rec.709 color space. With this set up, the contrast and white seems quite off. If i change the HDP2’s RGB Range to ”Full”, it’s 98% spot on compare to our other Sony grading monitors. I also believe the manual suggest Full RGB range….is there a reason why some people have it at SMPTE on the HDP2 for broadcast work ??
    My set up is:
    iMac 27”, OS 10.8.4, 32GB ram, 256 SSD
    AJA IO XT with color Space set to ” auto Detect” and RGB range set to ”SMPTE”
    Peragus R4
    AJA HDP2
    Dreamcolor set to REC.709
    Anhtu Vu replied 12 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
