Activity › Forums › Adobe After Effects › dream effect
dream effect
Posted by Trevor Jung on July 29, 2005 at 9:05 pmdoes anyone have any ideas for producing a dream sequence effect using either after effects of premier? I have no ideas other than to do just a motion blur
Theredmunkey replied 21 years, 1 month ago 3 Members · 2 Replies -
Andrew Kramer
July 29, 2005 at 9:23 pmwell one way might be…
use the echo time filter to create a faux slow shutter, you can also create a vignette that has blurred edges.Pre-compose your final sequence and thend duplicate an instance over top the original and then add a round mask to the top layer, invert the mask, feather the edges, and then add a fast blur and remember to repeat edge pixels.
you could also use a glow filter to give it that blown out look on some highlights.
Andrew
Theredmunkey
July 30, 2005 at 4:20 amI would also recommend trying this.
In AfterFX take your video layer and duplicate it (ctrl+D). Make the transfer mode multiply for the top layer. Then add a gaussian blur of 15-30 (I like around a 24) to the top layer. If the effect is too extreme you can lower the opacity of the top layer. You also might want to precomp the whole thing and play with the contrast/brightness etc. as multiplying tends to darken things. If your dream sequence is morose or not pleasant you can try totally desaturating the top layer for a bleach bypassy look. Or if your sequence is really upbeat and magical try upping the saturation.
This in addition to the vignetting, glow etc. should produce a really nice dream effect.
Hope I’ve been helpfull ^.^
-Sebastian
