Activity Forums Adobe Premiere Pro Dreaded .MTS files!!!
  • Dreaded .MTS files!!!
    Posted by Matt Jones on August 19, 2013 at 4:08 am
    Ok, I’m a FCP editor, but I do like Premiere (CS5) and use it when I can. A client sent me some .MTS files to do a very simple edit for a wedding. The footage looks awful in Premiere when I import from my drive. I checked my sequence settings, and they match. I tried all kinds of output formats using PP and Encoder, and it still looks poor. The original footage was downloaded from Dropbox, and looked better when previewed through the website. I wanted to test in FCP, but don’t really want to shell out the $50 for a converter, if it ends up looking just as bad. Could this just simply be the case of footage breakdown, have I overlooked an essential Premiere function or am I missing something very basic?
    Thanks in advance gentlemen!
    Adobe PP CS5
    Mac OSX 10.6.8
    Footage: 1920×1080 AVCHD (.mts) 29.97 fps
    Daniel Ludwig replied 13 years, 1 month ago 6 Members · 7 Replies
  • 7 Replies
  • Daniel Peterson
    August 19, 2013 at 4:21 am
    I don’t think you’re missing anything, I had major headaches working with .mts footage in the past too… though CS6 and CC seem heaps better at handling .MTS footage now….
    I know you said you don’t want to shell out the $50, but I was in the same situation and Clipwrap (https://www.divergentmedia.com/clipwrap) has been more than worth the $50. You can also seamlessly join clips together, optimised for PrPro.
    But if you want to try something else first there is a few free options listed here also… https://sites.google.com/site/karstenschluter/mts-to-mov
    Remux worked for ok for me for a few projects but Clipwrap is better.
    Hope that helps.
    Filmmaker | Motion Graphic Artist
    http://www.saltmedia.net
    http://www.TheDigitalSlice.com (beta)
    Seeking clarity in digital post production. Help us gather some data!
  • Vince Becquiot
    August 19, 2013 at 4:40 am
    Hi Matt,
    Have you checked your clip interpretation settings?
    Many times Premiere will just guess these settings. Start with a progressive 1920×1080 square pixels timeline, and interpret the footage as progressive.
    If that looks bad, then try upper field first, same for timeline. Export for results, don’t trust the preview.
    I should add that some cheap cameras don’t follow encoding standards, so all bets are off when it comes to third party consumer footage.
    Vince Becquiot
    Kaptis Media
    Indigo Live
    San Francisco – Bay Area
  • Ericbowen
    August 19, 2013 at 9:33 pm
    Convert the Media with this trial and see how it looks:
    https://cineform.com/products/gopro-cineform-studio-premium
    Eric-ADK
    Tech Manager
  • Angelo Lorenzo
    August 20, 2013 at 1:09 am
    IIRC Cineform is free for HD and smaller frames.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Matt Jones
    August 20, 2013 at 2:33 am
    You fellas are awesome. Seriously.
    Thank you for the suggestions, I will be trying these different options asap.
  • Matt Jones
    August 20, 2013 at 4:40 am
    Solved!
    I used the AVCCAM Restorer found on the link posted by Daniel:
    I then used the Log and Transfer method with Final Cut, and it worked! The software restored the folder structure found on the SD Card, and essentially “fooled” FCP into thinking I was transferring directly from an the original card. Brilliant! Thank you all again for the direction!
    Oh and I still love Adobe Premiere, too 🙂
  • Daniel Ludwig
    August 21, 2013 at 11:08 am
    why not used clipwrap to create pro res-files out of it and edit within FCP??
