Activity Forums Maxon Cinema 4D Drawing tangent to arc in splines?
  • Drawing tangent to arc in splines?
    Posted by Corrado Carlevaro on May 13, 2011 at 1:59 pm
    is there a way to draw tangents to arcs while drawing splines, as in picture below? I know I can round corners with Chamfer but this way I can’t have precise geometric control (tangent handles, center of arc etc.).
    Related questions: when I use a spline as a guide and Snap Settings set to Spline to help me modeling, and I move a point along e.g. X axis, the point snaps to the guide spline also moving in Y direction. Is there a way to constraint the snap only along the axis I’m actually moving?
    Is there a better tool for drawing splines and import them in Cinema 4D (I don’t like Illustrator)?
    Thank you
    Corrado Carlevaro
    Corrado Carlevaro replied 12 years, 2 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    May 16, 2011 at 1:59 pm
    You should turn on tangent snapping in the snap settings. So first you would create the circle splines. Then go into linear spline drawing mode and turn on tangent snapping. Draw your linear spline close to the two circles and then, in points mode, move the linear spline’s end points around the circle splines. Tangent snapping should snap them into the correct position.
    That said, I generally do this sort of mechanical line drawing in Rhino 3D. I’m sure other CAD applications are also quite good for this.
  • Corrado Carlevaro
    May 16, 2011 at 5:34 pm
    Thank you, very useful, as always, and the Rhino tip too.
    Corrado Carlevaro
  • Toby Hallam
    June 27, 2014 at 3:14 pm
    I dont see “tangent snapping” in the snap settings. I am running R15, so possibly it has been moved since this thread started, but I have to say I dont remember seeing there in any previous versions.
    any idea where tangent snapping is these days?
  • Corrado Carlevaro
    June 29, 2014 at 1:49 pm
    Well, actually I never saw a tangent snapping and never figured out a way to draw tangents in c4D, I’m afraid. I guess Adam was explaining how to do that in Rhino
