Activity Forums Adobe After Effects Drawing In AE/tracing bezier paths
  • Drawing In AE/tracing bezier paths
    Posted by Espnetboy3 on March 6, 2007 at 1:39 am
    I have a picture with lines in photoshop that are seperate layers. I want to have the picture or at least the lines draw themselves out on the page. I figure id bring it to AE and have a blank screen then have the lines start to draw out. Anyone have suggestions to do this. Thanks
    David Bogie replied 19 years, 6 months ago 3 Members · 2 Replies
  • Kyle Hamrick
    March 6, 2007 at 2:18 am
    If I understand your question correctly, you’re going to want to use the Stroke effect. Create a solid or adjustment layer, trace your lines using the pen tool, then apply Stroke. Animate the Start and/or End point, and you’ll be in business.
    OR
    Depending on how complex your object is, you can also bring your PSD in as a comp, then use the Write-On effect. Just animate your write-on brush tracing out the shapes in question, then set the effect to reveal the layer – this is down near the bottom of the effect controls.
    Good luck.
  • David Bogie
    March 6, 2007 at 3:26 pm
    This might help:
    https://www.adobeforums.com/cgi-bin/webx/.3bc351bc/2
    bogiesan
