Activity › Forums › Adobe After Effects › Drawing Effect
  • Drawing Effect
    Posted by Mark Adams on September 1, 2010 at 11:37 am
    Hi All,
    I’m wondering if someone could help me out with a project I’m working on. I’m not sure what you call it, but I’m trying to make an image appear on screen, like it is being drawn, so the line starts as a dot and traces out the image of an object. I know that’s not a very clear way of expressing the effect I’m looking for, but hopefully you know the lines along which I’m going.
    Thanks in advance,
    Creon
    Mark Adams replied 15 years, 11 months ago 2 Members · 2 Replies
  • John Cuevas
    September 1, 2010 at 1:08 pm
    Probably the easiest way to accomplish this effect is with the Stroke effect found in the Generate group.
    You would start by using the pen tool to create masks around what you want to draw. When you are finished add the stroke effect and animate the end property. Change the paint style to “on transparent”
    You might also add a “roughen edges” effect to give the lines a more organic look. Another thing to play with is the “scribble” effect.
    Johnny Cuevas, Editor
    http://www.thinkck.com
  • Mark Adams
    October 10, 2010 at 1:03 am
    Hi John,
    I’m starting with a simple line for this effect, just to learn the basis of what it’s about. So, I’ve drawn my curved line with the pen tool and saved it as an animation preset. I’ve then added the stroke effect and played around with the settings. I followed your advice, and nothing happens. Bear in mind, I am an AE noob, and really only know about rotating objects and making them zoom in and out of a frame.
    And pointers as to where I’m going wrong would be a great help!!
    Many thanks,
    Mark
