Activity › Forums › Adobe After Effects › Drawing a route with a plane on a map
Posted by Jean-guy Lamontagne on July 26, 2008 at 9:23 pmHow to realize an animation of a plane flying on a map tracing the route to be followed while leaving a red ligne after its passage?
Help pleaseMatthew De jongh replied 15 years, 9 months ago 4 Members · 5 Replies -
Daryl Booth
July 27, 2008 at 6:51 amOk, something like….
Use Photoshop or similair to create the red dotted line route.
Got to after fx
Import red dotted line as layer and drop into your comp
Open your plane layer.Drop into the comp. Right click, then select TRANFORM from the pop up menu. Look for orient along path.select it
On your plane layer use MOTION SKECTH to draw desired path (use your red layer as a guide.
draw a mask over the red route layer. use mask transform tool to edit shape to reveal the path as the animation progresses.
Tha should do it.
Sorry if its a bit clunky. mail me if you need any more info.
salutations from codemonkey
Simon Bonner
July 28, 2008 at 12:48 amHi Jean-Guy,
I have a 2-part video tutorial on my youtube channel (link below) on this very topic.
Simon Bonner
youtube.com/simonsaysFX -
Jean-guy Lamontagne
August 1, 2008 at 2:00 pmThank you very much Simon for your videos. Easy to understand. I tried it and it’s easy to do.
Matthew De jongh
November 29, 2010 at 11:28 pmplease repost link…there was no link in the post that i read
matthew
