Activity › Forums › Panasonic Cameras › Drawback of not being able to change lens?
  • Drawback of not being able to change lens?
    Posted by Web.boards on August 10, 2007 at 1:40 am
    What is the advantage of having the ability to use interchangeable lenses if you can just use an adapter lens like you can with the HVX? What are we missing out on by not being able to physically take the lens off and switch it with another one?
    Thanks.
    Michael Sacci replied 19 years, 1 month ago 4 Members · 3 Replies
  • Noah Kadner
    August 10, 2007 at 2:24 pm
    Depth of field and cinema style effects to a certain degree. If you have to ask you’re probably not going to miss them one bit.
    Noah
    Unlock the secrets of the DVX100 and now Apple Color!
    https://www.callboxlive.com
  • Russell Lasson
    August 10, 2007 at 5:31 pm
    Some lens adaptors reduce the light going to the CCD.
    -Russ
  • Michael Sacci
    August 19, 2007 at 4:11 am
    You also lose a lot of wide end of the zoom, w/ the 1.6x the first 30-40% of the zoom vignettes but with the 2x I would say about 80-90% of the zoom vignettes. I have used 1.6x and the added zoom is really nice and I need to pull the image in and could not get physically closer so I could live with the lose on the wide side.
    Also these are big heavy pieces of glass, making it almost impossible to handhold the camera.
    If you really need a lot more power often seriously look at the HPX500.
