Activity Forums VEGAS Pro Draw a path on the map
  • Draw a path on the map
    Posted by Joe Gaziv on August 27, 2008 at 9:38 pm
    I there a way to draw a pregressive path on a map in Vegas8 or it must be done in external application?
    Joe Gaziv replied 18 years ago 3 Members · 4 Replies
  • Terry Esslinger
    August 27, 2008 at 10:38 pm
  • John Rofrano
    August 27, 2008 at 10:48 pm
    Probably the easiest way to do this all within Vegas is use a piece of Solid Color generated media. Create the path using the Mask tool. This gives the most flexibility in revealing the path via keyframes. For a simple path, you can create the entire path using the mask tool and then just apply a Push transition to reveal it over time. This way doesn’t require any keyframes.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Joe Gaziv
    August 29, 2008 at 12:42 am
    Hi Terry,
    I tried the Mapliner you’ve referred me to. Although it has some limitations, I can live with it (and it’s free).
    Thx a lot,
    Joe
  • Joe Gaziv
    August 29, 2008 at 12:46 am
    Hi John,
    I am not sure I know to follow your method but I’ll give it a try.
    Thx a lot,
    Joe
