Activity › Forums › Avid Media Composer › Dragging clips to a sequence and ignoring source in and out points
  • Dragging clips to a sequence and ignoring source in and out points
    Posted by Juan Juig on June 14, 2021 at 9:59 pm
    Hello,
    is there a way to select all clips (in a certain bin) that contain “in” and “out” points, drag them to a new sequence and ignore the “in” and “out” points that are set on the source clips?
    The thing is that I have synced the raw clips with their corresponding sound clips and I have set the “in” points. Now I want to drag the raw clips (not the synced ones) to the timeline and also want them to include everything before the “in” points.
    I don’t want to remove the “in” points in case I need to sync some clips again later, so I’m wondering if there is a way to ignore them, while dragging them to the timeline?
    Best regards,
    Juan
    Ann Foo replied 5 years, 3 months ago 3 Members · 4 Replies
  • Ann Foo
    June 14, 2021 at 11:17 pm
    I think the answer is no. If you have an in point marked, thats what you’ll get pasted into the sequence, that’s the whole point of a mark-in. Only way around that is to delete the mark-in.
    My question is why are you using a Mark-in as a sync point anyway… this all sounds very clunky. You should be creating sync-ed subclips to edit with. If you do that, you’ll never have to worry about finding a sync point again.
    If, for whatever reason, you are hell bent on marking that sync point in your master clips, I suggest you mark it with a Marker instead of with a Mark-In.
  • Pat Horridge
    June 15, 2021 at 6:14 am
    Select a the clips in the source bin (ctrl A)
    Then press G to clear In and Out points.
  • Juan Juig
    June 15, 2021 at 6:57 am
    Thank you for the replies. Of course I created the synced subclips. I just wanted to keep the in points in original clips just in case. Guess I’ll clear them.
    Cheers
  • Ann Foo
    June 15, 2021 at 2:17 pm
    You can add a marker on the mark in point if you really need to keep that mark.
