Activity › Forums › Adobe Premiere Pro › Drag/Drop Video Without Audio Track?
Posted by Richard Christy on March 12, 2012 at 6:18 pmI need to drag and drop footage from the import bin into my Timeline without it bringing the audio track along with it.
Is there a way to set certain videos in the bin to “unlink” it’s audio track so when I drag it into the Timeline it brings just the video? The audio track is messing up things in my work flow and I don’t need them.
Any ideas?
Alberto Botturi replied 11 years, 11 months ago 8 Members · 15 Replies -
Ann Bens
March 12, 2012 at 6:41 pmNot from the bin, only from the Source monitor.
Adobe Certified Expert Premiere Pro
Adobe Community Professional -
Tom Prigge
March 12, 2012 at 8:48 pmTo be a little more specific than Ann, in your source monitor you will see a little icon that looks like a strip of film. Grab that icon and drag it to the timeline. That will only bring the video. Likewise, there is a little speaker horn icon next to the film strip. Grabbing that will only bring the audio.
Erik Mickelson
March 12, 2012 at 11:58 pmYou can also just deselect the “target” switches in the timeline. “a1,a2,a3” etc…
This will ensure that only video is brought in. Conversely, it works the same for bringing only audio in. Uncheck the video “target” track and only audio will come in.
Cuz sometimes that’s what you want the timeline to behave like.
CrippleBook Pro 2.3Ghz i7, 8GB ram, SLeopard 10.6.8, FCPStudio 3, QT 7
Paul Neumann
March 13, 2012 at 1:13 amAnd if you do bring it in by mistake a simple alt/option click on the track and delete will take care of it.
Cliff Stephenson
March 13, 2012 at 7:20 amActually, it’s fairly easy (as long as you know you won’t need the audio).
From your bin, right click on your track (or tracks, you can do a bunch at once) and select ‘modify’ ‘audio channels’ and then uncheck all of the audio channels you don’t want (presumably you wouldn’t have any checked if you don’t want audio at all). Then when you drag a clip from either the bin or the source window, it’ll bring in video only. But, like everything else, once you do that and drop that clip in the timeline, you won’t be able to change it back. You would have to right click ‘duplicate’ the clip and then you could get audio back on the dup.
But the nice thing is that you can alter/remove audio from every clip at once (again, as long as you haven’t used that clip in the timeline yet. Then, again, you’d have to dup it and remove the audio on the dup.
Make sense?
Richard Christy
March 13, 2012 at 3:40 pm@ Tom Prigge
Yes, that actually worked pretty much as I wanted it to. The only problem is sometime I don’t always have the Source Monitor open…but this is a workable solution.
@ Erik Mickelson
I can’t find this. I tried deselecting the Audio Tracks in the Timeline but it still brings the audio track in from the bin. I’m using CS4 by the way, not sure if that makes a difference.
@ Cliff Stephenson
I’d like to try this method but when I Right-Click on my footage in the bin, I do not see a “modify audio channels” option. Again, I’m using CS4 so not sure if that makes a difference.
Thanks for the info all!
Paul Neumann
March 13, 2012 at 5:30 pmOn CS5.5 it’s “modify” then another flyout for “audio”. It’s really an elegant solution. Thanks Cliff.
Paul Neumann
March 13, 2012 at 7:54 pmYeah, I can’t remember back to to CS4 to tell you if it even exists in that version. Sorry.
Alex Udell
March 13, 2012 at 9:47 pmI’m not sure about the modify approach because that’s a modification of a clip property.
in some instances pulling video only is a case based situation.
going thru the source viewer is probably the best approach.
honestly…
Adobe needs to update the software so that dragging to the timeline always respects that track patching.
What makes this difficult right now is that the sequence relationship for patching is always to the source monitor. It doesn’t “know” about the source you’ve selected in the project panel so the default is simply to override the patching and take everything.
Alex
