Activity Forums Adobe After Effects Drag to change value – weird behaviour
  • Drag to change value – weird behaviour
    Posted by Frank Feijen on December 13, 2010 at 7:30 pm
    Hi there,
    Weird stuff happens when i try to drag-change a value.
    For instance, but the same applies to other values:
    I want to enlarge my typed text, so normally i would simply drag/slide (howwould you call it) with my cursor and it would enlarge in relation to the travelled cursor-distance.
    Now instead of gradually increasing it just jumps to a size of 1296 pixels. Which is a bit large for most cases.
    I am using a wacom intuos 3, but the same seems to happen when i use a mouse.
    CS5, Mac Pro, Snow Leopard…
    Frank Feijen replied 15 years, 8 months ago 2 Members · 4 Replies
  • Frank Feijen
    December 13, 2010 at 7:51 pm
    it’s 10.0.1.19
  • Kevin Camp
    December 13, 2010 at 8:10 pm
    not having problems here (cs5, osx 10.5, no tablet).
    how about hovering over the value and using the mouses scroll wheel?
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Frank Feijen
    December 13, 2010 at 8:13 pm
    Good idea, but doesn.t work either.
    Actually wether i use mouse or wacom or cursorkeys, to value just jumps to the max value. The only way to lower it again is typing it.
  • Frank Feijen
    December 13, 2010 at 8:42 pm
    Yeah, found it!
    It was all due to a faulty plugin….
