Activity › Forums › Adobe After Effects › DPX, TIFF, EXR Problems – Can’t render Black & – export doesn’t match original
  • DPX, TIFF, EXR Problems – Can’t render Black & – export doesn’t match original
    Posted by Eli Rezik on December 16, 2013 at 6:45 pm
    Hey guys,
    So recently I’m working on a project and I was asked by the post house to export most of my files in DPX and the titles I made in EXR and TIFF.
    I’ve encountered some serious problems that I couldn’t fix, I hope you can help me.
    1) DPX Can’t render black
    In one of the shots, the actress is walking and I was asked to do a black transition that crawls behind her,
    I made a simple black layer with an animated mask.
    When I rendered the file, the black was gone and I could see the original footage!
    I did succeed on this one by setting the blacks in the DPX export settings to 1. Did I do it right? or did I just ruin it ?
    2) EXR and TIFF files when re-imported to after effects are shorter
    Two accidents here.
    First I exported the titles in EXR – Zip Compression and the Editor said it was a mess and not timed as we planned.
    Second I exported them in TIFF files and when re-imported the sequence is just shorter. I interpret them to the right frame rate and yet it still didn’t work right
    3) DPX Export is shorter than sequence
    This may be just a bug in after effects CC but, I exported a sequence 4 times and the DPX file numbers didn’t match the number of Frames.
    I changed the sequence name (????) and It worked fine! why?
    PS. all DPX files are 10bit and all Tiffs were Floating point RGB + Alpha
    Thanks in advance for your help
    Eli
    https://www.youtube.com/elireo
    Eli Rezik replied 12 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
