Activity Forums Adobe Media Encoder DPX sequence fixed to 29.97 fps?
  • DPX sequence fixed to 29.97 fps?
    Posted by Frank Andersson on February 27, 2012 at 2:40 pm
    I have shot some footage on a Sony F3 at 1080p25, captured with a Gemini 4:4:4 as 1080p25 4:4:4 DPX frames. So far so good.
    Long story short I ended up with choosing Adobe Media Encoder for transcoding to ProRes4444, since Compressor and FCP required GlueTools etc. and it seems that Adobe Media Encoder do a great job….but:
    If I import my DPX sequence to After Effects or Premiere Pro it interpret correctly to 25fps, and if I send it to Adobe Media Encoder from Premiere Pro it says 25fps, but I would like to go directly to Adobe Media Encoder with my DPX sequences – but that way it reads the source as 29.97fps!
    I can’t find anywhere to alter the source framerate so Adobe Media Encoder will see it as 25fps….any suggestions what this all about?
    Thanks in advance!
    Frank Buck
    .: Denmark :.
    Nicholas Musurca replied 12 years, 10 months ago 2 Members · 2 Replies
  • Frank Andersson
    May 2, 2012 at 9:24 am
    Anyone?
    Frank Buck
    .: Denmark :.
  • Nicholas Musurca
    October 16, 2013 at 9:24 am
    It may be too late for you, but I ran into the same problem and found a solution:
    1) Add your DPX sequence(s) to the queue.
    2) Select all sequences by Apple-clicking on the clip names one at a time.
    2) Right-click on one clip name in the queue and select the “Interpret Footage…” option.
    3) Select “Assume this Frame Rate” and type in the source framerate of your DPX footage.
