Activity › Forums › Adobe After Effects › DPX plus crash AE
DPX plus crash AE
Posted by Diego Stehle on October 20, 2013 at 10:54 pmHello everyone,
Im trying to export a DPX Plus sequence form After Effects. I’m having trouble doing it, because every time I try to render, AE crashes and shuts down. I don’t understand why this is happening since I already tried exporting in many different formats, even DPX Cineon works.
Any help would be very much appreciated.
Todd Kopriva replied 12 years, 10 months ago 5 Members · 8 Replies -
Todd Kopriva
October 21, 2013 at 2:09 amWe need to know a lot more to help you. Please provide answers to the questions listed here:
“FAQ: What information should I provide when asking a question on this forum?”———————————————————————————————————
After Effects team blog
Conrad Olson
October 21, 2013 at 4:41 pm -
Diego Stehle
October 21, 2013 at 6:26 pmThanks for your reply Conrad.
From what I had understood, DPX Plus allows for 8, 10, 12 or 16 bit DPX files + Alpha within Ae.
Conrad Olson
October 21, 2013 at 6:29 pmI haven’t heard of DPX Plus so you might be right. All I know is that Nuke lets you setup a DPX render with an alpha channel, but then it fails in render.
G. scott Scribner
November 6, 2013 at 9:36 pmRender in the command line. I have the same problem with AE’s GUI.
Diego Stehle
November 6, 2013 at 9:43 pmAWESOME, I´LL LOOK INTO IT. HOPE IT WORKS. THANKS FOR YOUR REPLY
Lgeorge
November 12, 2013 at 5:26 amI need to use DPXPLUS this week. I have the zip download… what procedure did you use to plant the plug-in. My plug-in folder won’t accept the file. Any other advice? I have 12 bit dpx stuff.
Todd Kopriva
November 12, 2013 at 6:26 pmIf you have After Effects CC (12.0 or 12.1), you don’t need to install anything additional.
