Activity › Forums › Adobe Premiere Pro › DPX output from SG not fully importing
  • DPX output from SG not fully importing
    Posted by Hugh Murray on October 19, 2013 at 10:25 pm
    I’ve just jumped into the Adobe editing world after stubbornly sticking with FCP7 these past couple of years (yes, I’m old skool).
    I just graded my first 20 min test project in SG, output as dpx (following the adobe tutorial), and for some reason Premiere will just import the first 6 mins (when I select single clip upon import). I even tried a 2 min dpx output test from SG and again, PP just imported the first clip of the 2 min sequence. I check the designated output folder and all the dpx files are there that would equal the length of my exported sequence. And yet, Premiere just imports a fragment of what it should. Any suggestions?
    Many thanks
    Chris Gunningham replied 12 years, 11 months ago 2 Members · 5 Replies
  • Chris Gunningham
    October 19, 2013 at 10:49 pm
    How are you importing? Via media browser or file import?
    Chris Gunningham
    Online/VFX Editor
    Any opinions expressed are solely my own.
  • Hugh Murray
    October 20, 2013 at 12:38 am
    Hello Chris – just using file import in PP.
  • Chris Gunningham
    October 20, 2013 at 8:17 am
    Hmm, never seen this problem. Does after effects import the right length? If it does you could import into there and import the ae comp into premiere. Also the new release this month has direct link to/from speedgrade so that could help.
    Chris Gunningham
    Online/VFX Editor
  • Hugh Murray
    October 20, 2013 at 4:50 pm
    Aye, same thing happens in AE. It’s bizarre, no two ways about it.
  • Chris Gunningham
    October 21, 2013 at 8:49 pm
    There must be a corrupt or missing frame in the sequence. Try a re render.
    Chris Gunningham
    Online/VFX Editor
