Activity Forums Avid Media Composer DPX only importing the first 99 frames
  • DPX only importing the first 99 frames
    Posted by Ricky Milling on October 4, 2019 at 8:30 pm
    Hi all, im adding a lot of VFX shots (normal/alpha) for a film and most of them are coming in fine, however ive noticed that some are being cut off at the 99 frame mark rather than the full amount, in this case 108 frames.
    I have no idea what is going on or why this is happening, any advice?
    In resolve the full 108 frames are imported.
    Im working iwth a 25fps project and the DPXs are also 25fps.
    Currently working on 2018.12.2
    Ricky Milling replied 6 years, 11 months ago 3 Members · 3 Replies
  • Michael Phillips
    October 5, 2019 at 2:51 am
    What’s the numbering format look like from the 99th and the 100th frame?
    Michael
  • Glenn Sakatch
    October 5, 2019 at 3:44 pm
    Yes you might want to run them through a batch numbering process to add some leading 0’s so that all files have the same number of digits.
    file_000099.dpx
    file_000100.dpx
    vs
    file99.dpx
    file100.dpx
    Glenn
  • Ricky Milling
    October 6, 2019 at 6:18 pm
    bch001_v06.098
    bch001_v06.099
    bch001_v06.100
    bch001_v06.101
    Will ask them to have a look at the files in this case.
