Activity › Forums › Adobe After Effects › DPX Frame Numbers / Timecode are offset by one frame in AE
  • DPX Frame Numbers / Timecode are offset by one frame in AE
    Posted by Jon Merrifield on September 6, 2013 at 10:10 pm
    CS6
    MacPro 4,1
    DPX frame numbers can be translated to timecode. This is easy math with the appropriate frame rate.
    Calculators online can help do this, (i.e.: https://www.michaelcinquin.com/tools/timecode_keykode
    frame 84600 (at 23.976fps or 24) should be 1:00:00:00.
    It is in Premiere Pro, it is in SpeedGrade, and in using the calculator above.
    In AE, it is 00:59:59:23
    You try it, make a comp’s starting frame 84600 and see what it is timecode wise at 23.976
    I have tried for the life of me to find some setting or preference that is causing this to no avail.
    Thank you.
    Jon Merrifield
    VFX Supervisor / Creative Director
    PELi Studios
    Jon Merrifield replied 13 years ago 2 Members · 2 Replies
