Activity › Forums › Cinematography › DPX files Export after effects
  • DPX files Export after effects
    Posted by Gon Perdigao on January 14, 2013 at 2:13 pm
    Hi There,
    I think this is the best place to add this post.
    I have to export my project to cineon dpx log 10 bit.
    All project was made in linear workflow with 16 bit and the reply for the cinema is that everything is too bright and washed.
    I Was thinking on doing a 10 test of different settings and send to the cinema.
    But this is not the best way to do it because if it goes to another cinema, and if they use different settings i would have to do it all over again.
    Is there any rule, or settings that i might apply to my export that might work out?
    Did u have this problem before?
    And even when compare the DPX files to the YUV or the Animation, it is in fact much more brighter.
    Thanks a lot
    Gon Perdigao replied 13 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
