Activity › Forums › Adobe Premiere Pro › Downscaling HD to SD for broadcaster on output
  • Downscaling HD to SD for broadcaster on output
    Posted by Richard Cullen on July 23, 2014 at 9:15 am
    I have a 1920×1080 sequence in PPro CC 2014 that I need to deliver to a broadcaster. Their spec is 720×576 as they only accept SD ads. Before in FCP7 I could select PAL 720×576 on export and it would come out right. However when I go to export the sequence from PPro and set the export size to 720×576 with 1.09 pixel aspect, the output is letterboxed. I know there is a drop down menu at the top of the export window for stretch to fill, scale to fill etc but none of those are changing what gets outputted.
    This seemed so easy in FCP and I’d love to get this figured out for PPro
    Richard Cullen replied 12 years, 2 months ago 5 Members · 8 Replies
  • 8 Replies
  • Jon Doughtie
    July 23, 2014 at 2:09 pm
    It is possible I am misunderstanding you. But since 1920×1080 is a 16:9 AR, and 720×576 is not a 16:9 AR, a letterboxed appearance is exactly what you would expect, I would think.
    If you want to force it to full screen in 720×576, your video will be stretched vertically and look a bit odd.
  • Jeff Pulera
    July 23, 2014 at 3:28 pm
    Check with the broadcaster and see if they broadcast at 4:3. If so, you will need to determine how you’re going to convert 16:9 to 4:3 –
    Letterbox
    Squish
    Crop 16:9 to 4:3
    Jeff Pulera
    Safe Harbor Computers
  • Richard Cullen
    July 23, 2014 at 3:54 pm
    in fcp, for example, it would appear in quicktime as 720×576 and it would be full frame but squashed in. this is how the broadcaster accepts it and then when the ad is aired it appears fine. so i assume when exporting in ppro i’d select the stretch to fill option, but this doesn’t change the output. if i export a 1080 version and then bring it in to media encoder it comes out how i would expect, but i don’t really want to to export and bring back in and export again.
  • Chris Borjis
    July 23, 2014 at 4:27 pm
    something in the exporter setting seems different than the setting in media encoder.
    It should export it anamorphic (stretch to fill)
    I wonder if it’s a bug in cc 2014. I heard an update is coming since
    AME CC 2014 has an h.264 issue to be resolved.
  • Myles Conti
    July 24, 2014 at 11:45 am
    Hi, I use the stretch to fill option all the time for SD broadcast delivery – always working off HD timelines. In fact I delivered to station on Monday using PP CC 14 – and everything appeared fine, I did this through PP not Media Encoder, but use either regularly without experiencing these problems, so don’t think its an issue with 2014.
    Myles Conti
    Director/Editor
    contibrosfilms.com
  • Richard Cullen
    July 24, 2014 at 12:50 pm
    Hi Myles,
    Would you be able to post a screen grab of your settings so I can compare to mine?
  • Myles Conti
    July 24, 2014 at 11:33 pm
    Hi Richard,
    Here are two screenshots for different TVC delivery. One of them allows you to upload 1024×576 whereas the other is what is actually broadcast and is 720×576
    Hope this helps
    Myles Conti
    Director/Editor
    contibrosfilms.com
  • Richard Cullen
    July 25, 2014 at 9:33 am
    its for IMD? perfect. that’s who I’m supplying to 🙂 will try this out. thanks
