Activity Forums Adobe After Effects Downscaling Disaster Advice Please ;(
  • Downscaling Disaster Advice Please ;(
    Posted by Farhan Ali on November 9, 2014 at 2:04 pm
    Hello everyone, so my BluRay project went smoothly the quality and audio along with visual effects was excellent. I assume the BluRay where set in 1080p quality.
    Now I have encountered the biggest problem ever. I was hoping to create DvD versions of my projects using Dual Layer Disc which hold 8.5GB.
    Using Adobe Encore I’ve burnt my BluRay project onto DvD and it has been a disaster. The quality, visual effects along with audio is not great, actually it sucks really bad. But when I looked at the file size of the DvD it was only 4.8GB?
    I really need some advice, is there a way to downscale 1080p to 720p and then burn 720p onto DvD?
    I would really appreciate any help.
    Thank you very much.
    Jane Kong replied 11 years, 8 months ago 3 Members · 7 Replies
  • 7 Replies
  • Chris Wright
    November 9, 2014 at 3:59 pm
    .mts supports AVCHD DVD-5 or 9 discs although they cannot be played in a standard DVD player, but can be played in many Blu-ray Disc players as long as the bitrate is below 18 Mbit/s.
    most blueray players support AVCHD at 1080p(including ps3) so you don’t even need to worry about downscaling.
    Just use a burning preset called bluray compatible AVCHD. some players even support .mp4 via network or usb disk,
    yep…usb disk 🙂
    https://www.avchd-info.org/format/index.html
  • Farhan Ali
    November 9, 2014 at 4:12 pm
    Hello Chris Wright, thanks for you’re response. My client wanted DvD format because some of his friends and families do not have BluRay player.
  • Chris Wright
    November 9, 2014 at 4:14 pm
    now if you want to hand out dvd player disks, use a third party frame scaler to 480p, then burning out a dvd-9 compliant with constant bitrate 8,500 Mbit/s(total should not go over 10 with audio,subs) to get best quality.
    1. Apple Compressor works good for rescaling
    2. a free plugin
    https://sites.google.com/site/katisvideotoolbox/smooth-bspline-scaler
    use with crosscale pixel bender accelerator to load pbg file if you’re newer than cs5.5
    3. trial$
    https://www.infognition.com/super_resolution/
    4. red giant instant hd
    https://www.redgiant.com/products/all/instant-4k/
    p.s. remember to deinterlace before scaling if you have interlaced footage!
  • Farhan Ali
    November 9, 2014 at 6:00 pm
    Hello, thanks for your recommendations. Just did some quick research and looks like Reg Giant Instant HD looks to be reasonable. I’ll be purchasing the plugin, I hope it’s an easy plugin to use.
    Have you used any of the plugins you have mentioned before?
  • Farhan Ali
    November 9, 2014 at 6:29 pm
    I’ve purchased Reg Giant Instant HD, how do I use the plugin?
    Sorry for asking silly questions just that I usually use Sony Vegas. I only use Adobe Effects & Adobe Encore when it comes to authoring.
  • Chris Wright
    November 14, 2014 at 4:51 pm
    it only supports in ae and premiere. it should have an install. set it to the plugins/effects folder.
    it will be under red giant if i remember correctly. add it to a composition.
    support https://www.redgiant.com/support/
  • Jane Kong
    December 23, 2014 at 2:53 am
    BD and DVD has different file structure, you can use some converters to convert your files into VOB, and in most converters , there are adjust settings for users to up or down their parameters
