Activity › Forums › Apple Final Cut Pro Legacy › Downloading for broadcast
Posted by Krista Dunn on July 15, 2009 at 7:00 pmWe are shooting HD 1280x 720 24fps….editing in FCP, need to output for local broadcast stations at 720×486 NTSC 29.97 fps. How to do this with best resolution and no distortion? Seems like COMPRESSOR is the best way. I tried animation NTSC, H.264 and Apple Pro Res 422 settings…all with good results. I would be grateful for any pointers. Thanks.
Andy Mees replied 17 years, 2 months ago 5 Members · 8 Replies -
Shane Ross
July 15, 2009 at 7:33 pmDo they want TAPE or a digital file? They should be providing a spec sheet that indicates what they want and how they want it.
Shane
Read my blog, Little Frog in High Def -
John Fishback
July 15, 2009 at 7:39 pmIf you have a Kona or other i/o card or box, you can downconvert in real time to tape. Most people agree this produces higher quality results than Compressor. That said, Compressor can do the job if you can deliver your program as a file. Ask the broadcaster if they have a preference of file format.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Krista Dunn
July 15, 2009 at 8:05 pmI am delivering a quicktime file to stations. I have tried some tests and there is some distoration (vertical stretch) in the image when I cut in the native size and download thru Compressor. (people look thinner!) Any way you know of to avoid this? Thank you!
Doug Beal
July 15, 2009 at 9:42 pmthe process you want is downconverting not downloading and in order to maintain aspect ratio from the native HD footage you need to “letterbox” the footage or 4:3 “centercut” which preserves your height but cuts off the sides.
what you are getting now is an anamorphic image which is also referred to as “squeeze” This is acceptable for DVD authoring but not for broadcast. they’ll want “letterbox” or “center cut”Doug Beal
Editor / Engineer
Rock Creative Images
Nashville TN -
Andy Mees
July 17, 2009 at 4:01 pmHi Krista
As recommended earlier, check with your traget broadcaster as to their requirements/preference. Doug’s advice here, with respect, is not always necessarily correct, inasmuch as broadcasters might indeed prefer an anamorphic master which they can repurpose as desired eg 16:9, 14:9 or 4:3.
Hope it helps
Andy -
Doug Beal
July 20, 2009 at 10:25 amHello Andy
I agree, as Shane said earlier, check with the broadcaster for their specs, however I was responding to her comment/question
” (people look thinner!) Any way you know of to avoid this? Thank you!”Doug Beal
Editor / Engineer
Nashville TN -
Andy Mees
July 20, 2009 at 12:16 pmI hear you Doug, and as noted, my comment was “with respect”. No offense was intended.
I was hoping to clarify only that part of your post where it stated what you are getting now is an anamorphic image which is also referred to as “squeeze” This is acceptable for DVD authoring but not for broadcast. they’ll want “letterbox” or “center cut” which I though had the potential for misinterpretation by other less experienced viewers of this thread.
Hope that explains my post a bit better
Best Regards
Andy Mees
