Activity Forums Apple Final Cut Pro Legacy Downgrading to SD from FCP for DVD studio Pro
  • Downgrading to SD from FCP for DVD studio Pro
    Posted by Leon Willis on November 9, 2012 at 7:10 pm
    HI,
    I am export an HD 90min 3 camera concert from FCP to Compressor to build in Dvd STudio Pro on a Dual Layer Disk. It needs to be in SD. WIll I loose quality if I downgrade to SD on final cut export – or – is it better to export from final cut in HD and then downgrade to SD from Compressor.
    Hope this makes sense.
    Thanks in advance
    L
    Francisco Baudet replied 13 years, 4 months ago 2 Members · 3 Replies
  • Leon Willis
    November 9, 2012 at 10:21 pm
    Great Thanks Dave. I have used ‘send to compressor’ option from FCP. Ive broken it into 9 sections so I can send each separately to keep file sizes down. From compressor I am creating both SD dvd files & HD for safety!
    Thanks again.
    L
  • Leon Willis
    November 9, 2012 at 10:46 pm
    Ok thanks. I am ok for storage, I thought the computer prefers smaller files, this is the only reason I was opting for 9 parts. I will go for your option, as your right ‘send to’ doesn’t seem to be doing much.
    Cheers
    L
  • Francisco Baudet
    May 26, 2013 at 2:30 pm
    Hi Dave.
    Despite all settings and using proper videos,
    DVD Studio Pro only generates HVDVD_TS files
    and never Video_TS files.
    Would you have a solution ?
    Many thanks.
    Francisco.
