Downconverting HD to SD issue
In the Blackmagic Control Panel I have PROCESSING on output set to “HD to HD and SD Center Cut.” I see the downconvert fine on the monitor that is connected to the deck. I black a tape, then go to Assemble edit and BOOM! Nothing. Black. Why?
Is it now sending an HD signal to that Component connection? Because it says HD to HD and SD…why do that? I ONLY want SD. So if it is sending out both signals, how does it know which needs to go down what pipe?
This is seriously hitting me… I’m yanking the card out in 30 min if I can’t figure it out, going back to MXO2.
Shane
