Activity › Forums › Apple Final Cut Pro Legacy › Downconverting HD->SD PAR question
  • Downconverting HD->SD PAR question
    Posted by Accountneedsrealnameupdate on March 13, 2007 at 10:36 pm
    I have a question that might sound very stupid, but I thought I’d try :
    If I have footage that was shot on a Varicam in DVCPROHD-720p, the PAR is 1.33. If I downconvert this to fit onto a regular 16/9 codec such as DV NTSC, that has a different PAR, won’t things look squashed? Is there a way to avoid this?
    Alex
    Chris Borjis replied 19 years, 6 months ago 3 Members · 3 Replies
  • Walter Biscardi
    March 13, 2007 at 10:48 pm
    [disciple1] “If I have footage that was shot on a Varicam in DVCPROHD-720p, the PAR is 1.33. If I downconvert this to fit onto a regular 16/9 codec such as DV NTSC, that has a different PAR, won’t things look squashed? Is there a way to avoid this?”
    FCP takes care of this for you automatically using the Distort function. If you drop the 720p material into a DV timeline, you’ll get an automatic letterbox resizing of the footage. From that, you can reset it to whatever framing you want.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Accountneedsrealnameupdate
    March 13, 2007 at 11:53 pm
    I was actually using DV NTSC as an example. My final output will be Digitbeta or BetaSp (not sure yet), so I will be creating a 8bit uncompressed timeline at the end of my project to export the baby.
    So I’m glad FCP will do that…I tried a simple export using QuickTime from DVCPRO HD to DV NTSC Widescreen, and there was some very visible squeezing…
    Alex
  • Chris Borjis
    March 14, 2007 at 12:29 am
    I’ve been testing a number of downconversion techniques from
    HD to SD and I have found that nesting your HD sequence into an
    uncompressed 10 or 8-bit SD sequence, then exporting to compressor
    yields the highest quality.
