Activity Forums Blackmagic Design downconvert quality question Luke
  • downconvert quality question Luke
    Posted by Paul Provost on October 30, 2006 at 3:29 pm
    the previous thread got a little side tracked
    here’s my question
    Hi Luke
    Is the hardware downconversion of the multibridge extreme as good as the $15,000 option on a HD deck you were talking about?
    Also can you get better results in a downconvert in final cut putting an HD clip in a BMD 10 bit SD sequence (easy setup) and rendering out instead of using a decklink extreme for realtime downconvert?
    what we were doing was downconverting dvcpro hd 720 23.98 to digibeta
    selecting the “letterbox” option in the bmd system pref looked pretty awful on realtime downconvert
    outputting 16×9 anamorphic looked much better, so we did that, recaptured the sd from digibeta then converted to letterbox in fcp and output again to letterbox. It worked, but is there a better workflow/quality?
    thanks
    Chris Borjis replied 19 years, 6 months ago 2 Members · 3 Replies
  • Chris Borjis
    October 30, 2006 at 11:05 pm
    are you doing this in hardware or software on the downconvert settings?
    software looks awful, always has and I wonder why its even an option.
  • Paul Provost
    October 31, 2006 at 4:23 am
    I’m not sure waht you mean
    I have a decklink extreme and my preference window only has a choice of letterbox or 16 x 9
  • Chris Borjis
    October 31, 2006 at 7:06 pm
    sorry, I was talking about the hardware conversion in the multibridge extreme.
