Activity › Forums › AJA Video Systems › Downconvert Input through Kona 2?
  • Downconvert Input through Kona 2?
    Posted by Matt Larson on March 23, 2007 at 9:34 pm
    I am hoping to downconvert some 720p30 footage to Anamorphic SD for capture, is this possible with the Kona 2? I had expected to be able to select a secondary option like I would for a downconverted output.
    If this is not an option on the Kona 2, is it an option on the Kona 3?
    I have a Panasonic 1400 deck hooked up HD-SDI to Kona 2 in a dual G5 running Mac OS X 10.4.8 with FCP 5.1.2 and XRAID.
    Bonus points if you can just tell me how to have the 1400 play downconverted video from the HD-SDI output.
    Matt Larson replied 19 years, 6 months ago 4 Members · 4 Replies
  • David Roth weiss
    March 24, 2007 at 1:26 am
    Matt,
    Select the Easy Setup in FCP for the format that you wish to capture and capture.
    DRW
  • Walter Biscardi
    March 24, 2007 at 11:34 am
    [Matt Larson] “Bonus points if you can just tell me how to have the 1400 play downconverted video from the HD-SDI output.”
    It doesn’t, you simply hook up the SD-SDI output for the downconvert.
    For capture, David gave you the answer. Choose an Anamorphic SD format and capture.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Bob Zelin
    March 24, 2007 at 1:35 pm
    Matt writes –
    REPLY –
    Matt. You say you have a Panasonic 1400 VTR. Have you even looked at the back of your VTR ? Do you see where the SD-SDI output is? Do you see where the composite video monitor output is ? Is it just easier to type on the computer, than to pick your behind up, bend down, and look behind the VTR ? (My apologies to you if you are a student, and have never used a VTR in your life before).
    Bob ZElin
  • Matt Larson
    March 26, 2007 at 2:33 pm
    [Bob Zelin] “Matt. You say you have a Panasonic 1400 VTR. Have you even looked at the back of your VTR ? Do you see where the SD-SDI output is? Do you see where the composite video monitor output is ? Is it just easier to type on the computer, than to pick your behind up, bend down, and look behind the VTR ? (My apologies to you if you are a student, and have never used a VTR in your life before).”
    Bob – SD means Standard Def? I thought it meant Student Discount!
    I didn’t think it was that unreasonable of a question to ask if a Pansonic VTR can play both SD and HD over HD-SDI since I have 2 Pansonic monitors that allow both standards over one cable. Not to mention the all-mighty Kona card does the same. As does my router.
    It looks like I WILL have to “pick my behind up” take down a cabinet, roll out 3 Middle Atlantic enclosed racks, build a cable, and hook the deck up over SD-SDI.
    I guess I should be glad it’s one cable and not 6 Component, 8 XLR, TC and sync…
