Activity Forums Avid Media Composer Downconvert dropping frames
  • Downconvert dropping frames
    Posted by Derek Peerally on February 5, 2010 at 1:31 pm
    When downconverting 59.94 sequences to an SD deck, I have sometimes run across “dropped frames” which will stop the Digital Cut even when the master clips are fine. I have output these sequences to HD with no problem. The dropped frames do not seem to be part of the footage as they sometimes will capture after multiple attempts, more like an error upon either the Video Output Tool, the Avid Version, or the Graphics card.
    I am an assistant editor & although I have done many outputs in my time, I have never run across this before & our deck has to go back today. EEEEk
    The first 4 episodes output without any issues, but as I move forward the dropped frames seem to be more frequent.
    These projects were also worked on by two other editors on 3 different systems but here are my specs because that is all I can account for.
    Thanks in advance,
    Derek Peerally
    Nitris, Media Composer 3.1.1
    Mac OS x10.5.4
    NVIDIA GeForce 8800 GT
    2x 3GHz Quad-Core Intel Xeon
    Michael Phillips replied 16 years, 7 months ago 2 Members · 1 Reply
  • Michael Phillips
    February 7, 2010 at 2:04 am
    Which Avid hardware are you using?
    Michael
    Michael Phillips
